Please help. I had a bright idea that I would back up all my MP3 files and DVD's on an external usb 500 gb WD 7200 rpm hard drive and play them from the drive instead of loading and unloading disc's. Well, when I boot up and play a (the first) movie or an mp3 file it sounds great. but, if I change to another movie or mp3 file it pops and cracks so loud and awful you might have heard it and just didn't know what it was;
Anyway, I have a Sound Blaster A2 sound card and a cheap set of Aztec speackers. However, it was not doing this prior to installing the WD 500gb hard drive. Now it does it with or without the WD HD connected.
Please, please, please, I have reseated the sound card, updated drivers, worked on it about 3 days and just can't get it to work right. I want to be able to open the hard drive, play a movie, play another movie or music files... Somebody please have an answer.
Thanks![]()
A nifty trick for comparing two .WAV files is to use the "Mix Paste"
feature of an audio editor like Cool Edit. Extract a track twice, then
use Mix Paste to copy an inverted version of one file on top of the other.
The two sound files will cancel each other out wherever they are identical,
and have little spikes where they are different. This can be useful
for seeing if the problems are only on one channel or are happening at
regular intervals.
Cracking Philips DVP3345
By ringosshed in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jan 2013, 08:57 -
Annoying popping sound after converting AVI to DVD
By Smudge249 in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 17:24 -
XBOX 360 HD-DVD sound popping when HD-DVD starts only with HDMI hookup
By vatkat234 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 15th Jan 2009, 21:03 -
Is Microsoft Cracking Down on DVD Ripping?
By rkr1958 in forum Latest Video NewsReplies: 41Last Post: 13th Feb 2008, 09:49 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 11:46
