i have some music clips that are in 320x240 resolution, so stretched out on the TV it looks pretty bad, however i think they would look ok at half size seeing as its a fairly large tv. So is there any way of putting like a frame around the picture so the original clip is in the middle of the screen? that way the low res isn't quite as noticeable. hope you get my meaning, its kinda hard to explain. Currently using TDA 3 to compile various clips off other dvds onto one with menu/chapters etc
If you use TMPGenc as redwudz suggests, I would say to output to 352x240 and not 720x480 as in his example. 352x240 is valid for DVD and will give you a much smaller border than to do 720x480. You could resize up to 720x480 with a border, but resizing will decrease your quality somewhat and I don't recommend that.
The Avisynth method is also a good suggestion, but Avisynth can be a little tough for newbies.
Doubling the size of a WMV video? (320x240 > 640x480)
By kingmustard123 in forum EditingReplies: 26Last Post: 9th Aug 2011, 07:32 -
upconvert DVD player for hi-res DivX video?
By joecass in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Apr 2011, 20:27 -
DVD Studio Pro -select Video, Audio and Subtitle track in low res for proof
By RonCole in forum MacReplies: 3Last Post: 3rd May 2010, 13:03 -
best lossy codec for 320x240 video
By videoasker in forum Video ConversionReplies: 12Last Post: 30th Jan 2010, 13:56 -
How to Crop a 720x480 video to make it 320x240?
By alc112 in forum EditingReplies: 3Last Post: 11th Jan 2009, 00:42
