Whats with these big black borders around the video? Whenever I try to full screen it in WMP it doesn't change to full screen, it just has these big black borders around it. This is AFTER I export my movie from Premiere. The original clips do NOT have these borders btw. Am I missing a setting? Thanks for your help![/img]
You are doing something wrong in premiere. How does the preview look like in premiere before you export? full screen? what export settings are you using?
My Export settings are:
General
File type - Microsoft DV AVI
Video settings
Compressor - DV NTSC
Color depth - Millions of colors
Frame size - 720 x 480 (grayed out)
Frame rate - 29.97
Pixel aspect ration - Square pixels (1.0)
I've tried to start the project using the settings for ''Video for windows'' and using a compressor like DivX. But still I get the same thing.
My gut tells me it has to do with these ''Action safe/Title safe'' options. Action safe is at 20% - Title Safe is at 10%. Thanks for your reply![/b] -
Yep, it sounds like the action safe options. Try set it to 0%. It has to do with the TV overscan.
odd problem: vid looks fine in vegas and AE but weak after rendering. ?
By tsimmons in forum Newbie / General discussionsReplies: 48Last Post: 28th Jun 2010, 05:13 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 02:13 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 01:49 -
Weird rendering borders from Premiere
By mv0930 in forum EditingReplies: 0Last Post: 11th Aug 2007, 15:38 -
Odd framerate for NTSC after rendering
By crimsonjade in forum Video ConversionReplies: 4Last Post: 28th Jul 2007, 19:35
[/img]
