I've got an AVI several generations removed from the original old TV capture.
One problem is that many scene transitions are scrambled and a bit jarring when viewed.
Eg, this sequence below, frames 3314, 3315, 3316.
I'm using Avisynth to filter and resize, so I'd like to also use it to replace the transition frame with the previous or next one, eg:
FreezeFrame(3315,3315,3314)
This gives a more pleasant viewing experience.
The problem is of course finding all the transition scenes.
If I could get a list of all scene changes by frame number I could quickly review and fix each one if necessary.
Since a lot of encoding software needs to know where scene changes are, it seems to me this problem must have been solved. Is there a way to do it in Avisynth (or VirtualDub)?
Results 1 to 1 of 1
How to detect what causes a system lockup?
By sdsumike619 in forum ComputerReplies: 45Last Post: 9th Jul 2014, 23:22 -
Detect Scene Change in x264
By Anakin in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2012, 19:31 -
How to detect FPS in a VOB?
By user2008 in forum Newbie / General discussionsReplies: 2Last Post: 21st May 2009, 15:13 -
PC can not detect Dv recorder
By dazedandamused in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 6th Apr 2009, 18:45 -
How to detect pillarboxing in AVISynth
By GoneToTheDogs in forum EditingReplies: 9Last Post: 18th May 2007, 22:36
