Hi, when i convert a matroska file using MKV2TS, it only processes the video, but not the audio.
this is how i created the MKV i am trying to convert
MKV>>>>Mkvextract>audio and video>>>h164info>video change to level 4.1>>>>ac3>re-encoded from 640KBPS to 320kbps(reduce file size)>>>>mkvmerge>merged both files>>>>MKV>>>>MKV2TS>>>>only processes the video, but not the audio,
Did I do anything wrong??![]()
I am trying to back up the x264 movies so i can record them on to a AVCHD Disc, playable in the PlayStation 3/Blu-Ray player.
I could just take the oryginal MKV and do MKV2TS, but at the end, the final file size is bigger than the oryginal, and WILL NOT FIT on to a DVD-5....
Results 1 to 1 of 1
Used mkvtoolnix and need help making audio from mka to ac3 Major help pleas
By csta in forum AudioReplies: 10Last Post: 2nd Aug 2017, 11:03 -
Pleas Help with intensity pro capture dropped frames issue
By jub2k3 in forum Capturing and VCRReplies: 14Last Post: 18th Jun 2010, 13:38 -
meGUI crashes whenever it tries to MUX and only if its 2 pass =/ Help Pleas
By Chrushev in forum Video ConversionReplies: 2Last Post: 5th Jan 2010, 05:38 -
Hi i'm a newbie having huge problems with Visual Hub for the Mac Help pleas
By twiglet31 in forum MacReplies: 3Last Post: 7th Aug 2008, 15:06 -
MKV2TS.......read in!!
By oldpainlessuk in forum Video ConversionReplies: 8Last Post: 8th Jun 2007, 08:31
