Is it possible to convert RM(Real Media) to dvd with that program?
If not is it possible to add an addon to make it possible?
Presumably if you can play the file in WMP then you should be able to do a one line avisynth script as per: https://forum.videohelp.com/topic331487.html
Let us know how you get on.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
