    Sep 2006
    I have purchased a remarkable software. It is called Audio DVD Creator. The site is at http://www.audio-dvd-creator.com/
    Audio DVD Creator creates a DVD disc from normal wave and MP3 files. The wave files are turned into *.BUP and *.VTS files. I have made many DVDs this way and they work and play extremely well.
    QUESTION: I want to make a copy of this DVD. And I have failed. I have used NERO, B's Recorder Gold, Clone CD, Clone DVD2, and DVD Decrypter. None will copy this disk. I don't understand why.
    Is there a software that will copy this disk?
    Could I go in reverse? That is, read the Audio DVD and turn the files back to seperate wave (or mp3 tracks) ?
    Thank you.
    bryan kendall
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Have you tried copying the files to your HDD and then burning as data?
    Google is your Friend
  3. Member yoda313's Avatar
    Jun 2004
    The Animus
    also try dvdfabdecrypter or ripit4me.
  4. DVDdecrypter in ISO READ then ISO WRITE should always able to copy a DVD.
    Feb 2004
    Australia
    Audio DVD Creator , seen it ... my two cents ... crap .
    Dose it have some flaws when you dig deep enough with the right tool's .
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    I tried it once too...didn't work very well.
    DVDDecrypter
    Ciler's AC3Tool
    CDWave or Goldwave.
    Done, free and better(IMO).
