Is it possible to convert a hd movie 720p or 1080p to a dvd and play it the xbox360 and still get the hd resolution??or do i have to get av hd dvd player?? or stream from my to the 360??
no
dvd is 720/704 * 480, dvd's cannot be made in HD 720P or 1080i, that why there are the new blu-ray an HD formats and disc's
does your 360 play dvix 6 files, then you can have ws-hd avi files in dvix and burn the avi file to the DVD-data disc and play the disc
or shop for a dvix compatiable dvd player,
lots of them on the market -
If you want HD, then you need the HD player (assuming you have an HD capable TV). There aren't any shortcuts.
Google is your Friend
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
Help encoding 360 x 360 videos (spherical movies)
By sapojow in forum Video Streaming DownloadingReplies: 29Last Post: 1st Aug 2009, 19:23 -
360 to DVD
By qwertybo in forum Capturing and VCRReplies: 6Last Post: 19th Dec 2008, 09:48 -
I did it... picked up a 360.
By Xylob the Destroyer in forum Off topicReplies: 12Last Post: 12th Jul 2008, 09:39 -
Can you interchange a xbox 360 hddvd drive between pc and 360?
By yoda313 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 23rd Oct 2007, 09:06
