I am looking to buy some speakers to add to my mixer, which is probably a Mackie mixer, and i wanted to get some suggestions. I looking to do it for some weddings and probably graduations. From my experience with the graduations, i only need 2 powerful speakers and that would be to the front. Tell me if I am wrong. With the weddings; however, i need at least four, depending on the size of the room. This is to my knowledge. I'm looking for some cost efficient and effective speakers, that is some cheap speakers. However,
I know a little about the specifications for a speaker and have tried reading it up several times and it has swelled my head. I know i should look at the driver type to see if its full range, 2 way or 3 way i think. There is the power so that i would know how much volume i could push towards the speaker without frying it and well that's about it.![]()
How's My English?
What you should be searching for is 'PA speakers'. Home stereo speakers aren't really made to be moved around like PA speakers are. Unfortunately, they aren't often cheap. You might look locally at some music shops as musicians sometimes end up defaulting on payments and they may have a good selection of used PA speakers.
PA usually refers to speakers made for hard use, high power, and portability.
Do they need to be powered speakers or passive? (Do you have a PA amp?) This company has a few guides that may help you figure out what you need: http://www.sweetwater.com/shop/live-sound/pa-speakers/ -
JBL, Electrovoice and Mackie are among the leaders for powered portable speaker systems. In most cities you can rent these by the day. I suggest you rent a few models before you decide to buy. Get some experience with them in different size rooms.
http://www.zzounds.com/cat--2725
In addition to the mixer, you'll need wireless microphones (Shure brand is most used). You can rent these as well.
This equipment can be shared with the bands in some cases.
What kind of speaker system is hooked up to your computer?
By johns0 in forum PollsReplies: 29Last Post: 22nd Feb 2012, 05:33 -
Suggest to me: inexpensive 5.1 speaker system
By RogerTango in forum Media Center PC / MediaCentersReplies: 0Last Post: 23rd Oct 2011, 20:34 -
Need a speaker system for the TV
By beavereater in forum Off topicReplies: 2Last Post: 7th Sep 2011, 19:18 -
5.1 speaker system
By vanderlyle in forum ComputerReplies: 3Last Post: 1st Sep 2010, 23:12 -
Samsung HT-Z210 best SPEAKER SETTING
By dzsoul in forum DVD & Blu-ray PlayersReplies: 1Last Post: 2nd Oct 2009, 05:43
