What is the best program to convert a file to mpeg so that i man make a dvd with and have the hughest quality?
Results 1 to 11 of 11
Do these work with vista because I used Tmpgenc Xpress 4.0 in xp but when I upgraded it didnt work anymore?
They should all run in Vista. I use TMPGEnc plus encoder and TDA and they work fine with Vista. Did you install them using 'Run as administrator'? Sometimes you may need to raise the VFAPI priority with TMPGEnc encoder, I don't know about Xpress. This may apply, not sure: http://www.digitalfaq.com/dvdguides/convert/tmpgenc/tmpgenc.htm Scroll down the page to 'Problem opening source files'.
Vista compatibility list: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List -
Which is better Tmpgenc plus or Tmpgenc xpress or is it a matter of preferences?
I think Xpress has the edge over regular Tmpgenc, just because it can convert to more formats, and I like the newer interface. Still, they're both really good, very reliable, but not terribly fast Mpeg2 encoders. Cinemacraft is faster, but I don't like the visual presentation of the program. I'm not smart enough, probably. HC is the one I use most, however. There's something I really like about free software.
Overall Cinemacraft is probably the better but thats mine opinion. I also like Tmpgenc plus....I guess its a toss up.
I tried tmpgenc xpress 4.0 and it did the file up until 99 percent then it had an error. What does this mean?
Have you looked in the error logs to see what messages might be there about the time it stopped ?
You need to give more details. Do you ring your mechanic and say "I was driving home and I got 10 feet from my house and my car stopped. What does this mean ?" and expect a realistic answer ?Read my blog here.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
Choppy playback of some MPEG-2 files and all IFO files
By ANOther1676 in forum Software PlayingReplies: 2Last Post: 8th May 2011, 06:04 -
Convert .mpeg-files to .vob-files?
By stuckinsnow in forum Authoring (DVD)Replies: 1Last Post: 21st Sep 2008, 04:06 -
No audio in powerdvd for mpeg 1 and mpeg 2 files
By Bully9 in forum AudioReplies: 2Last Post: 2nd Jan 2008, 07:23 -
DATA files rather than MPEG files from a DVD-Video?
By DieselsDen in forum Newbie / General discussionsReplies: 11Last Post: 14th Dec 2007, 03:24
