Well the display AR is either 4:3 or 16:9. Run the file through g-spot and also post a screenshot. You're thinking the picture itself might have a distorted AR.Originally Posted by Turbo Sensonic
The cropping numbers can be determined if you open the avs file(without resizing) in vdubmod:
video --> filters --> add --> null transform -- cropping
Results 31 to 39 of 39
Well the aspect will not be destorted because the normalOriginally Posted by Pinstripes23
DVD standard is 720x576 (PAL) and 720x480 (NTSC)
And here we have a video file which is a letterboxed 16:9 eg in a 4:3 format which
also have the format 720x576.
So the diffrence between 16:9 and 4:3 is that the picture in the movie have different sizes, but the
video format is the same 720x576.
The width is the same (720) the hieght differs. So the widescreen picture is streached when its viewed on the
tv screen...
The black bars at the sides have nothing to do with this.....
A film with the aspect 2.40:1 (PAL) has a hight of 300 pix but the videofile is still 720x576...
There are some Disney movies that have aspect 1.66:1 (PAL) the hight here is 434 pixels
So if his so called wiedscreen video clip has an aspect of 1.61:1 it will do fine becase the visual picture
is still 720x404 pixels (If it has that aspect)
No hard feelings Pinstripes23....
EDIT: If the width of the source isnt 720 then he must add black bars at the sides CORRECT !
Here is a link to a very informative site abput aspect ratios
http://lipas.uwasa.fi/~f76998/video/conversion/
And by the way
Im glad that you got it right Turbo Sensonic
stars.... -
If you have an already distorted picture from unknown source (you don't know how somebody cropped and resized it), you can only find correct displayed AR (it can be a non-standard one) experimentally by finding scenes with rounds, squares etc. and resizing (e.g. in VDub) for correct proportions. Knowing actual DAR (pixel ratio value providing undistorted image ) for your video, you can calculate resizing numbers for MPEG. DAR is the only necessary for calculations parameter of your video (the rest are standard numbers). I suggested a simple calculation table for any possible case in another thread:Originally Posted by Turbo Sensonic
https://forum.videohelp.com/topic333824.html
Alternatively (if you don't like calculations) you can use the popular FitCD utility. -
That's the resolution. The aspect ratio is determined by the encoder and authoring prog. Besides you can't look at those numbers as 1:1 pixel AR because that is not how it is going to be displayed on a TV anyway.Originally Posted by stars
So you agree that the picture is 1.78:1 inside the 4:3. So adding borders will distort the picture AR. You are forgetting that borders have to be contained within the 576 vertical resolution, so the vertical picture will get squashed down to 536 resolution. So when viewed on a TV it will be squashed vertically.Originally Posted by stars
Not if it is encoded, authored, and your tv is set up correctly it won't.Originally Posted by stars
Never said it did(if you're talking about the original source). I said you must compensate by adding black borders to the sides if you are going to add to the top and bottom. This is after cropping away all the black.Originally Posted by stars
But you agreed above it is 1.78:1 picture AR. So it isn't 1.61:1, so there's no point in bringing this up.Originally Posted by stars
I have already done my research on the subject a long time ago. And I've been creating dvd's for some time now and have encountered all sorts of strange picture AR's as sources. And I have no problems correcting them using avisynth.Originally Posted by stars -
720x404 are suitable final resize numbers for ripping a 16:9 movie to smth. like divx (from both PAL or NTSC). In case of DVD pixel numbers are never related as 1.78:1 for a 16:9 video. For PAL letterboxed image they are 720x432 and for NTSC 720x360.Originally Posted by stars
TrueOriginally Posted by Pinstripes23 -
oops...
I must have been steping on somebodys toes....
@Pinstripes23
Im not sure that we understand each other....So you agree that the picture is 1.78:1 inside the 4:3. So adding borders will distort the picture AR. You are forgetting that borders have to be contained within the 576 vertical resolution, so the vertical picture will get squashed down to 536 resolution. So when viewed on a TV it will be squashed vertically.
First of all we are talking about a video file that we really dont know much about..
What Im trying to say is that if you have a picture size of 720x404 we have an aspect ration of 1.78:1
which is full screen 16:9 (Im talking about picture size, the borders cut off)..
If we take the borders off and resize the picture to 720x576 which is DVD standard and
encode it with 16:9 flag. (You cannot encode it with the size 720x404)
Then we author the DVD as a 16:9 DVD....Then we would get a full widescreen DVD
The picture will not be destorted....(well if you look a the videofile in 4:3 mode it would look destorted)
as Alex_ander says there is a compensation for the overscan
So if the picture was 720x404 there is a possibility to add black borders (letterbox) so you wouldnt
lose any picture with the overscan.
stars.... -
not at allOriginally Posted by stars
Actually we do. The resolution in the original screenshot he posted is 720x576. So we know he took a screenshot of the dvd as is. And from there you can manipulate how it will look by cropping, adding borders, resizing, etc.Originally Posted by stars
Actually if you cut off the borders(from the original screenshot) the size becomes 690x432 not 720x404. You shouldn't be looking at DVD resolution as 1:1 pixel ratio.Originally Posted by stars
Ok I agree........but where was the add borders to the top and bottom you made in your previous posts? That was what I was disagreeing with. You made no mention of it just now. If you are going to add borders it will be part of the 576 vertical resolution like I said before.Originally Posted by stars
I think you are getting confused. 720x404 would be the AR if the PAR is 1:1. It has nothing to do with putting a picture within the 720x576 frame for DVD. Therefore you wouldn't use 720x404 when deciding if black borders should be added for overscan.Originally Posted by stars -
Im sorry when I meant cuting of the border I meant the ones at th top and botton.Actually if you cut off the borders(from the original screenshot) the size becomes 690x432 not 720x404. You shouldn't be looking at DVD resolution as 1:1 pixel ratio.
The ones at the left and right wouldnt show up anyway....
and for the overscan thing (adding borders) there is no need because of the hight of 432 pix..
So if I or (he) cut of the top and botton border we will get 720x432
And then resize it to 720x576 and encode it with a 16:9 flag....would this be right...???
stars... -
Yes for the most part that would be right. As the original was a WS letterboxed encoded as 4:3.Originally Posted by stars
Coverting Video File to DVD without changing Aspect Ratio
By dwpoze in forum Newbie / General discussionsReplies: 3Last Post: 11th Dec 2009, 03:35 -
Changing a DVD's Aspect Ratio
By soneman in forum Authoring (DVD)Replies: 11Last Post: 8th Sep 2009, 18:18 -
Changing aspect ratio.
By Lyceum in forum EditingReplies: 5Last Post: 28th May 2009, 12:19 -
Changing aspect ratio?
By Marlow in forum Video ConversionReplies: 2Last Post: 5th Apr 2009, 05:40 -
Changing an aspect ratio on DIVX
By diablo_jones999 in forum Video ConversionReplies: 13Last Post: 29th May 2007, 11:53
