I"m having a problem converting some avi file/files to dvd. I'm following this"Basic Guide How to Convert AVI Files to DVD with Avi2DVD" to the "T". I have had excellent success on 5 earlier trys with single avi file, but on one of my converts the it with through all the process and when it was done, PowerDVD couldn't find the video_ts file. I look at the temp file and it is half the size it should be for a dvd file. I can burn the file in nero and it will play on my dvd player and excellent picture but no sound. I can play the same file in nero showtime and it has picture and sound. My question is why does it work someti? here is some picture of the file I'm using, maybe you can see something I don't.
justmenow55
Well your pics seem to indicate a multiple AVI source. Are they all part of one video?
Well why don't you join the 2 AVIs first, and see how it goes. You could then use GSpot to see if the length etc., all seem correct.
With Vdub MP3 freeze or Surround.
https://www.videohelp.com/tools/Virtualdub_MP3_Freeze
http://www.digital-digest.com/articles/virtualdubmod_joinavi_page1.html
You can also join with AVI-Mux GUI
http://www.alexander-noe.com/video/amg/
problems with avi2dvd
By kayla33 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 14:12 -
Avi2dvd menu problems
By bman321 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2009, 20:18 -
Avi2dvd help
By morg55 in forum Video ConversionReplies: 3Last Post: 27th Mar 2008, 17:51 -
Problem with Background sound using AVI2DVD
By govtstooge in forum Newbie / General discussionsReplies: 3Last Post: 21st Dec 2007, 15:11 -
By justmenow55 in forum Video ConversionReplies: 1Last Post: 29th Jul 2007, 12:50
