Hi, so I have this AVI-movie and I have an .srt file to go with it.
I want to permanently add this subtitle to the movie and save it on disk.
I have tried and tried, but have been unsuccessful.
Maybe anyone can guide me through the process. I'd be mucho thankful...![]()
iMacG5usr
Results 1 to 13 of 13
If you want to "burn" the subs onto the video, then you'll have to pick a mencoder preset and encode the video with these subs to a new file, AVI or otherwise.
Open your file. Select a preset that uses the mencoder engine, e.g. XviD mencoder. In the Video tab, check the video size to match the source. In the Audio tab, check the various parameters to match the source. In the Filters tab, set your subtitle file. Set the type to "Burn". Use the Load subs button to select your subtitle file. The Options tab is optional. Encode.
I've already succeeded in encoding, thanks for the help, it's perfect.
Only the thing is... sometimes the converted file appears at the moment I press the encode button, and sometimes it doesn't.
Like now for instant, It's at 18 percent... and no converted file in the folder, is that wrong?
iMacG5Usr
I am just starting with this program so I don't know it all just yet, but wat am I doing wrong when the encoding is finished in 1 sec.
And when I locate the mencoder and check the box it unchecks the next time I look at it.
Videoguru's Please help...
Mac OS X isn't all that responsive in updating folder listings for files being created and made larger, like one would see with encoding files. Maybe Leopard will improve that?Originally Posted by iMacG5Usr
Have a look at the Log, it should list errors, if any. If you can't figure it out, post the content here for us to look at.Originally Posted by iMacG5Usr
Is this in the components self-installer window? You only have to do that once, if successful. If the components (binaries) are installed okay, then they are in black the next time you look at that window. If they are in red, try again. The binaries are copied to a special OS X location by the installer, so you may delete the downloaded files after a successful installation.Originally Posted by iMacG5Usr
I've captured the window, maybe i's of some help to you.
foto%202007-08-12%2012-58-42.tiff
Short answer: Try DMGs_and_Movies for a folder name.Originally Posted by iMacG5Usr
Long answer: Remember that ffmpegX is a GUI frontend for many underlying Unix tools. These tools operate by command line, just like using Terminal. One of the consequences of this is that it may be possible to do 'illegal' things (from a computer language POV), unless the developer made provisions for every possible thing that needs special handling to avoid these illegalities.
You seem to have a folder with the name DMG's and Movies. This folder has an apostrophe (') which has a special meaning in the command line language: the command line interpreter is looking for a quoted segment, thinking the first apostrophe is an opening quote, but never finds the end quote, thus fails. The developer has managed to escape many special characters for the ffmpeg engine, but not for the mplayer/mencoder engine and some other tools (yet).
Try to keep your disk name, folder names and file names 'clean': without spaces and special characters. At least the disk/folder/file names that ffmpegX may use.
32 kbps is quite low. I imagine even the source doesn't sound very clear. You could try a higher bitrate (say 128 kbps) or -even better- Passthrough (AVI output only) for a direct audio copy.
Alternatively, you could skip encoding and extract the audio from the source and multiplex it with the extracted new video. Not as simple, but faster on most systems, as video encoding takes the most time. Use D-Vision > Tools > Re-encoding avi/mpg for stream extraction from AVIs. The Mux tool in ffmpegX can multiplex the video and audio stream to a new AVI again. And if needed, run it through an AVI Fixer.
MKV Audio + AVI Video to avi using ffmpeg?
By kwanbis in forum Video ConversionReplies: 9Last Post: 15th Apr 2012, 20:45 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
FFmpeg: AVI to Rawvideo
By David_UK in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 09:07 -
FFMpeg AVI to H264
By Vertuas in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2008, 11:42 -
NTSC DV-AVI and ffmpeg
By Vertuas in forum Video ConversionReplies: 18Last Post: 29th Aug 2007, 07:32
