I have Magix Movie Edit Pro and I'm finding the help files very UNhelpful after switching from Cyberlink.
I am having a problem getting the frame on the menu to show a moving clip from the movie, ie my movie is divided into 11 chapters and I would like each chapter to be showing the movie from where that chapter starts. I'm not sure of the correct terminolgy to look this up.
I thought ticking the image preview was going to produce this effect but it doesn't.
When I try to search for 'image preview' there is nothing for this in the help files, and the online tutorial is worse than useless.
Can anyone help with this please?
Thanks, Gay
Usually it is called 'animated thumbnails' but it can be different in your software. Those are easily created in TDA2 or TDA3.
Thanks both.
I tried looking for that but I still can't find out how to do it.
Maybe Magix Movie Edit Pro can't do it?
I will try one more post to see if any knows how now I know what question to ask
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53 -
Virtuadub shows two different frame rates ?
By vodmare in forum Video ConversionReplies: 8Last Post: 12th May 2008, 19:47 -
Newbie looking for correct terminology so I can effectively search
By redraif in forum Newbie / General discussionsReplies: 6Last Post: 13th Jul 2007, 15:15 -
Correct Terminology for authoring?
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 2nd Jun 2007, 03:45 -
Baffled!! Titlewriter shows nothing but DVD Player shows Movie Name
By Subhash in forum Authoring (DVD)Replies: 16Last Post: 25th May 2007, 13:02
