I have 2 BUP files 2 IFO's and 5 VOB's, i have downloaded AGK but dont undertsand what im supposed to do, could sumone help me out please i need this in a high quality avi file within the hour....
1. You are going to miss your deadline. Not makeable if you knew what you were doing, which by "hi-quality AVI" I assume you mean a Divx or Xvid, as opposed to 20 Gig or so of uncompressed AVI. You could get an uncompressed AVI in one hour but you could not send or copy it to another medium in that time.
2. This is why such procedures are outlined fully and completely, with pictures and everything, in the Guides listed on your left.
3. You should also read the Dynamically Updated Master Breakdown for Acess to Superb Statements, also known as the FAQ. This will help you define your goal so as to ask questions that make sense. "AVI" is a generic term that requires more information.
4. At your stage of knowledge, you are most likely several days away from producing anything at all, more time required for "hi-Quality". Depends on your reading speed. -
ok do you speak english?
i have started using AGK and selected one of the ifo files, it is doing something...hopefully converting to avi, i jst need it in a normal video file so i can put it on my laptop and use my ipod conveter onit....it says english mpeg1 2ch/ 2cd 1400mb.
its 9% done, so why am i week away from having it done?
and i dont mean uncompressed video im not a tv broadcaster or anything, its just filmed in HD so i want it in nice quality.... -
i accidently pressed stop on virtual dub and it created a video file but there was no sound.....ive started again, could you tell me if im doing the right things so far?
Well, no, you are not. Can you read English?
You have failed to describe the source video accurately. You have a DVD file structure, but this is HD video???
You have not read the information available to you. Check the initials on my name for the FAQ. My version describes the person who has not read this document.
Sounds like you are going to do multiple conversion to get it to the IPOD. Very basic info is that multiple conversions are to be avoided at all costs, most particularly multiple compression cycles.
AGK is decent prog, but most likely an unneeded step. Direct conversion to desired format is best, if source format is unacceptable, then decompress source to raw or uncompressed AVI.
I said weeks for "hi-quality". Maybe longer, if you continue to refuse to read the complete instructions available here, along with other useful information. -
i dont have time to read it all right now im in a rush, i tryd burning it str8 to dvd but the dvd doesnt play on anything and when put in my mac it says its a blank disc, when u can clearly see it has been burned. windows trys to play it when i insert it like it recognizes its a dvd but then it just freezes
Yet your other post states it plays in WMP.
Since you can not be relied upon to provide reliable, useful, or meaningful information, that makes it difficult to solve your problem.
Since you do not have the time to begin to absorb the most basic info you should have, I do not have the time to teach you all the things you need to know.
I will revise my estimate of weeks to predicting you will never get it done by yourself.
Good luck, when you have shown you are prepared to put forth the necessary effort then try again.
Since you probably did not take time to check the initials I mentioned, the acronym for the person who does not read the FAQ and basic Guides is D U M B A S S.
Need to make IFO, BUP for Single VOB
By Simmons in forum Authoring (DVD)Replies: 5Last Post: 28th Aug 2011, 20:15 -
How can I create IFO + BUP files for a VOB file?
By mac&me in forum MacReplies: 3Last Post: 4th Dec 2010, 02:06 -
Burn - VOB without IFO & BUP files?
By Miss Sherlock in forum Authoring (DVD)Replies: 25Last Post: 24th Aug 2009, 00:20 -
Burn VOB without BUP IFO [Special]
By ron007 in forum Authoring (DVD)Replies: 1Last Post: 16th Feb 2009, 20:01 -
How to play a .vob .bup .ifo files?
By Kinstonian in forum Software PlayingReplies: 12Last Post: 19th Mar 2008, 16:26
