First timer here and will appreciate any guidence.
I have a Scientific Atlanta set-top box via Charter cable.
I have a Panasonic DMR-ES25 using HDMI to the TV.
I have an older Aquos LCD with the seperate I/O unit.
Everything is perfect except I can not play commercial DVD's unless I unplug the cable input to the DVR, they freeze after the commercials and previews prior to the main attraction. Once I unplug the cable, everything is fine.
If we record a program, in order to play it back and use the remote properly, we need to unplug the cable and again everything is fine.
It seems that there is a sort of HDMI/copyright handshaking thing going on. I called Panasonic and they new about it right away and suggested I watch their site for firmware updates but there have been none, and it has been months.
This is inconvenient, and occasionally we forget to plug the cable back in.
Is there anything I can do on this end to fix this annoyance?
Thanks for the look!
Joe
Strange. Sounds like a bug in the DVR, only thing I could think of would be to try Component out from the DVR to the TV, and use the HDMI for the cable box to the TV.
I agree, different video connections or the firmware update.
Google is your Friend -
Get a different a/v switch for your tv. Get it so you can seperate it with your dvd player as a seperate input. Then you can simply switch back and forth with a button.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Thank you everyone for the input!
@Nelson37-When I first called Panasonic, the first question from support was "is your STB Scientific Atlanta"?, he knew about this issue.
@Krispy Kritter-I did do a firmware update to bring the DVR current and there has been nothing since.
@yoda313 and Nelson37-My three year old Aquos has a separate AVC unit. It has one HDMI out to the LCD and only one HDMI in. It does have other inputs but I'm not willing to give up the increased quality of HDMI. The switch we use is to manually unplug the coax from the AVC unit, then everything is great. (;>)Joe -
If it is in fact a known bug, then the only fix will be via firmware.
A workaround, would be to use a different input (the bug is likely with HDMI). You shouldn't notice any visual quality difference between HDMI and component (especially not at the resolution you are likely running on your LCD).Google is your Friend
Add new subtitle to an existing DVD with warning screens, intros & trailers
By Charmer in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2011, 18:59 -
Titles Intros.
By ozab in forum EditingReplies: 3Last Post: 17th Feb 2009, 20:00 -
DVD Won't play past menu on laptop
By DVDLovers in forum Newbie / General discussionsReplies: 4Last Post: 11th Jan 2008, 13:24 -
DVD Intros
By Smudge249 in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2007, 20:44 -
Youtube .flv files quickly stop playing but will play past half way point
By video1312 in forum Software PlayingReplies: 1Last Post: 20th Sep 2007, 14:20
