    Aug 2007
    Australia
    Im currently using DVD Architect 4.0b and am having problems when I import videos that are MPEG format. The audio plays for like 3 seconds, then it just cuts out.
    Here's a picture:
    http://img.photobucket.com/albums/v223/Sharkboy/DVDARCHITECT.jpg
    Is there anyway around this or will I just have to re-save my videos as a different format?
    Apr 2004
    Miskatonic U
    If you listen to just the audio file, doe sit cut out ?
    If you load it into Audacity or similar, does it stop at the same place ?
    The most likely explanations are that this is all that was encoded, or the file is corrupt.
    Read my blog here.
    Aug 2007
    Australia
    The audio works fine when opened with anything else, its just in Architect.
    Apr 2004
    Miskatonic U
    I can only suggest you try re-encoding it, or use a different authoring tool.
    Read my blog here.
