Just got this for my laptop since it is running Vista, and the Nero I have won't work. The problem I am having is that it won't burn a compatible DVD of a folder. I copied over a dvd that I had already created with an older DVD Author, selected add folder, and burned it, but the disc just won't play on any DVD player.
Is there some special way that you have to tell it to make a video disc vs a data disc or something? Any help would be appreciated.
don't use nero
use imgbrn, dl it from here, and then select build mode and navigatge to 'folder'
it will use the video_ts folder and create a dvd
Burning a VIDEO_TS folder to disc makes it a playable DVD right ?
By Bansaw in forum Authoring (DVD)Replies: 25Last Post: 1st Mar 2015, 16:34 -
A Mac tool that can author .mpg to DVD folder for buring
By Sam0403 in forum Authoring (DVD)Replies: 5Last Post: 5th Mar 2012, 15:49 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 15:46 -
Burning DVD with VIDEO_TS Folder
By bguguen in forum MacReplies: 7Last Post: 28th Jul 2009, 01:10 -
Burning VIDEO_TS folder to a DVD disc as Video not Data
By xtaint in forum Authoring (DVD)Replies: 2Last Post: 3rd Aug 2008, 09:23
