Hi guys......
I will just cut to the cause...
Every time i try to run video with virtualdub i get a message that says " Xvid Decompressor couldn't be located "
i tried a couple of codec pack like C.C.C.P and tsunami but none of them them worked although tsunami pack would of worked only i kept getting message from windows BTW im using windows vista and using Virtualdub 1.4c
Help PLZ
Results 1 to 13 of 13
You need a VFW version of Xvid installed. If I remember correctly, CCCP (and probably a number of other codec packs) use ffdshow, so all you need to do is see if you have a folder for ffdshow somewhere in your Start Menu, then call up the 'VFW configuration' option, and enable Xvid decoding (go to Codecs, and set Xvid to be decoded using libavcodec, since you don't seem to have the Xvid codec itself installed.)
Edit: I'd actually recommend installing the regular Xvid codec over using ffdshow to decode Xvid (just follow the automatic link above), but I can't be sure if that would clash with any of the codec packs you've installed. Also, are you sure you want to be using an older version of VirtualDub? The latest versions are 1.6.19 and 1.7.2 experimental.
Edit #2: I'm confused - in your other post, you say you're using VirtualDub 1.7.2, but here, you say 1.4c.If cameras add ten pounds, why would people want to eat them? -
I'm really sorry to make two post for the same thing...
Ai Haibara
your way is to hard to do
and i didn't know that there was a newer version of virtualdub
isn't there a simpler one
BTW i will install any think that i need
and i installed Xvid codec 1.1.3.they are working with windows media player.... -
Try using AVI Fourcc Code Changer and make sure the fourcc codes are "xvid" (all lower case) on the top, "XVID" (all upper case) on the bottom
I tried a cuople of things and one wotked but this is my problem now
[img=http://img258.imageshack.us/img258/1561/untitledug9.th.jpg] -
https://forum.videohelp.com/topic300624.html?sid=5d7b74aa2964d9768cb1c6f1bb98f1ec
This guide uses older versions of Virtualdub, GSpot and Goldwave.
If you don't have Goldwave, you can skip step 5 through step 8 and just reinsert the uncompressed wave back into Virtualdub. This will work on most VBR files but Goldwave may have to be used on some.
You can also use a program called Avidemux that will rewrite the header and timecode of the damaged AVI and will fix most VBR files. There will be some files that it won't fix and you'll need to fix manually the Virtualdub way. -
Another thing that usually works is to use VirtualDubMod instead of VirtualDub. When VirtualDubMod opens the file it will ask if you want to rewrite the header -- answer NO. Then use full processing mode on the audio and recompress to CBR MP3 or whatever other codec you want.
Lets look at this from another angle..
I open virtualdubmod > open mpg
Streams >stream list >rt click on stream >full processing mode > rt click again on that stream > compression ...
This is the root of the problem ( i think). I am unable to get any newly installed codecs to show up in this window. I have lame installed and a few others. They are not here tho....
There is one called MPEG Layer-3, when i check the "show all formats" box , nothing is displayed in the window.
I read that using 32 bit codecs in a 64 bit os wont work. Is this the problem>?>
Please help... -
please delete the above ( and this one). I replied to wrong post..
sorry
No audio decompressor could be found using VirtualDub
By dapster in forum Newbie / General discussionsReplies: 22Last Post: 6th Jun 2015, 04:25 -
VirtualDub - No audio decompressor could be found.
By kelemvor in forum Video ConversionReplies: 25Last Post: 24th Jan 2013, 16:36 -
Vorbis decompressor for virtualdub
By mkr10001 in forum AudioReplies: 2Last Post: 14th Mar 2012, 12:58 -
VirtualDub Error 'Says "Couldnt locate decompressor for format xvid"
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2010, 23:05 -
virtualdub Xvid Decompressor couldn't be located
By unkown in forum EditingReplies: 5Last Post: 11th Aug 2007, 04:21
