Hi
I'm capturing using Huffyuv and its quite crisp clear
however it captures at around 25/30gb per hour...
is it possible to increase the compression?
because there aren't much options in the ..options menu..
thanks
Divx 6 is pretty fast if you set Encoding Mode to Fastest. Use 1-pass Quality Based encoding with a quantizer of 2 or 3. Disable B frames (automatic if you use Fastest) and set the keyframe interval to 1 for better editability.
huffyuv help
By liquidr0x in forum Video ConversionReplies: 31Last Post: 18th Feb 2015, 06:31 -
How do I install Huffyuv (mt)?
By blud in forum Newbie / General discussionsReplies: 8Last Post: 6th Apr 2012, 06:47 -
HuffYUV Question.....
By vipin in forum Video ConversionReplies: 7Last Post: 7th May 2010, 12:36 -
H.264 to HuffYUV
By PuzZLeR in forum Video ConversionReplies: 13Last Post: 4th Apr 2008, 00:25 -
How can I uninstall Huffyuv?
By Xoanon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 15th Jun 2007, 09:55
