I am getting a message on my monitor (home computer) that says something like - no input signal. I am not getting anything other than that and don't know what would cause it. Any help would be appreciated. Also, what would be the best spot to get this fixed in the Phoenix area?
I know this sounds obvious but it is plugged into the video out on the computer isn't it?
What the monitor is telling you is thatit is not recieving input from it's selected source.
It could be you have the cable plugged into the wrong socket on the back or you need to cycle through the input options until you find the one you are connected to.
Equally it could be simply that the plugs aren't pushed fully home.
If possible test you computer with another monitor and your monitor on another computer.
Without details of the monitor it's difficult to suggest anything else.
If it's under guarantee contact the sellerabout getting it fixed otherwise my experience has been it's cheaper to replace than fix (sad tho' it is to say in the environmentally aware days) -
I checked to make sure that all connections were correct and pushed fully home. I checked the computer with another monitor and still received nothing. What could it be inside the computer that would cause it?
That's not good news
When you power up the machine does it beep and/or flash the lights on the keyboard -
essentially does it appear to power up (except no output to the monitor)
If it does it might be the graphics card - although that in itself might mean a new Motherboard
If there are no beeps or flahing lights it suggests the Motherboard or processor or PSU has gone and you are into the fun of diagnosing what has actually failed.
Check to see if your drives power up and fans spin etc - if they do it's probably that the PSU is good.
Also check the fuses! I've spent many hours in the past diagnosing a non starting machine to discover the fuse was blown so there was no power to the machine
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 14:14 -
An LCD TV without 75 ohm coax input install where only a coax input can be
By dss4u in forum Newbie / General discussionsReplies: 4Last Post: 12th Nov 2009, 12:09 -
mic input -realtime denoise -> sent as input to dragon naturally speakin
By logicom in forum AudioReplies: 0Last Post: 27th Sep 2009, 11:46 -
Subtitle Input string not correct format/Input subtitle file error (SOLVED)
By Webgirl in forum SubtitleReplies: 8Last Post: 13th Mar 2008, 08:59 -
help to set up a dvr and satellite signal input box, please
By The Muddler in forum DVD & Blu-ray RecordersReplies: 7Last Post: 14th Jan 2008, 13:33
