I think I've got PowerDVD on my laptop but I'd like to find a free software download
(or a trial if needs be) that shows the bitrate of the dvd as it's playing.
I only want it to test the bitrate of recorded footage using a JVC MH300 dvdrw, and compare direct to dvd / hd>dvd. The second dual-pass method is supposed to increase the VBR ie lower in still, higher in action. So I'd like to see if it's worth it. I have a dvd player which shows bitrate but it doesn't look accurate to me.
MPEG 2 Validator will graphically display the bit rate of MPEG2 files. I just tried it and it can read .VOB as well as .MPG.
https://www.videohelp.com/tools/MPEG_Validator -
Right-click on the video screen and check Show Information.Originally Posted by TJohns
no not powerdvd, windvd thats the one, sorry. I probably have it some where on disk though.
BTW I mean't to monitor bitrate in real-time as opposed to for the whole vid, but I think from the replies you've understood that.
I'll try 'mpeg validator' it sounds good, cheers for the replies.
After searching for similar, I've downloaded 'Bit-rate Viewer' too,
it seems like a handy, and easy too use utility.
https://www.videohelp.com/tools/DVD_Bit_Rate_Viewer -
Thanks, I've tried MPEG_Validator and it's great.
Everyone should have it.
Second by second bitrate and clear graphs for quick comparisons.
And it gives the frame size so I could check for the bitrate when the frame size half's.
I've used it for my tests and the JVC HDD>DVD dualpass method does extend the bitrate levels by +1Mb and -1Mb, so now I know.
Which software that can display 2 different subtitles while playing movie?
By JackyWang in forum Software PlayingReplies: 2Last Post: 29th May 2011, 08:43 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 01:36 -
what software converts to DVD with manual video bitrate control
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2008, 13:09 -
graphical bitrate display
By ziv_r in forum Newbie / General discussionsReplies: 5Last Post: 26th Dec 2007, 09:18 -
m2v file stops to display frames during playing
By Fendervr in forum Video ConversionReplies: 2Last Post: 22nd Aug 2007, 13:43
