I used mydvd studio 6 to encode dv video to dvd. the dvd video has horizontal lines when motion occurs. It almost appears to be shifting "slabs" of existing video by 1-2% of screen width. I edited the dv into avi clips before importing.Would this matter?
Results 1 to 15 of 15
AnonymousGuest
You've been here since 2001 and have over 3000 posts, so can I assume this is something other than normal interlace lines? How about a screenshot?
Buy My Books -
AnonymousGuest
They would seem to have to do with interlacing.Normal? i dunno? I dont like it if it is normal. I dont see it with my other dvds made by the same process. I will post a pic when I get home.
3000 posts?Well, those were all OT.
2001?I'm still posting in the newbie section. -
If it's DV make sure you're using bottom field first.
Off topic: 2516 posts / 83.75% to be exact.Originally Posted by Dr.Gee
Whoa..my first POST.....yea!!!
anyway, im having the same prob with Mydvd8. If i export the project to Mpeg....it plays fine (no lines when panning) and (just burning it to a DVD) apears fine on TV. But if i use MYDVD to burn a disc, with menus, chapters yadda yadda.....it streaks with every motion.
im hoping that someone can help with this, so i will be following your post.....good luck to us! -
AnonymousGuestThat's it. not as bad though.Originally Posted by jimmalenko
Field order? I dont understand Greek.I'll have to research it.
%83 OT? I've been slacking.
Each frame of interlaced video contains half of two separate pictures. Each half picture was taken at a different point in time. When you watch this on TV you see only one half picture at a time, first one, then the other. The field order determines which of those pictures you see first.Originally Posted by Dr.Gee
Some media players will deinterlace on-the-fly, some won't. Or are you talking about a set-top DVD player?Originally Posted by Dr.Gee
Field Order need to be change................
AnonymousGuestNo. Media Center on a Vista machine. Can I get a codec for this?Originally Posted by jagabo
That's the problem then. A computer monitor is progressive and displays each field as a frame, a TV is interlaced and displays as it was intended to be. A DVD on a pc monitor usually looks pretty horrible at the best of times. PowerDVD does a reasonable job of displaying interlaced TV footage but it still isn't as good as the cheapest set top player and a TV. This of course assumes that PowerDVD will run under Vista, it seems there's more software that won't than will.
Lines On Desktop
By jjis in forum ComputerReplies: 4Last Post: 16th Dec 2010, 14:11 -
sub lines too long
By 45tripp in forum SubtitleReplies: 2Last Post: 26th Mar 2008, 10:58 -
Why are there lines in my video?
By Mysteriouskk in forum Video ConversionReplies: 8Last Post: 6th Dec 2007, 21:30 -
Where do these lines come from?
By RedFarmer in forum Capturing and VCRReplies: 8Last Post: 6th Nov 2007, 06:13 -
Lines
By snake2589 in forum Video ConversionReplies: 1Last Post: 2nd Aug 2007, 19:08
