hi all i have an avi video that has 12 meg size. I want to change audio of this file only without making the file size so huge. I used Virtualdubmod and followed the following insruction but i end up with huge huge file like 300 meg !! could any one tell me how to dubb without making the size of file too huge. i want this video for youtube .looking forward for reply.
Virtualdubmod. Streams -> Stream List. Click Add and select your new audio. Click on the old audio and click on Disable. Save th new clip using Direct Stream Copy mode.
The key is to use direct stream for video and audio. If you have video set to direct stream, any size change is due to different audio file sizes.
/Mats -
Thank you for you reply. the audio that i want to add is mp3 and it is around 3 meg. I am currentling dubbing and i see the files size is increasing beyond 700 meg!!! is it compressing it at the end?Originally Posted by mats.hogberg
could you tell me how to use direct stream? how to set to video to direct stream? My whole intention is that after dubbing the file size dosn't exceed too much since i want to upload it to youtube and it takes time for 60 meg above file size!!! -
(This is from VirtualDubMod)
/Mats
can I remove dubbing on an avi file?
By pattirose in forum Newbie / General discussionsReplies: 29Last Post: 15th Sep 2015, 11:42 -
AVI files make DVD huge
By dishwater63 in forum Authoring (DVD)Replies: 6Last Post: 13th Dec 2010, 19:09 -
quicktime pro will exporting to h.264 solve this huge file size issue?
By cybershot in forum Newbie / General discussionsReplies: 7Last Post: 10th Oct 2010, 21:43 -
I need to edit a huge .avi file
By Hobittual in forum EditingReplies: 2Last Post: 25th May 2010, 15:40 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 17:31
