I have my family album, video avi clips playing on my standalone dvd player.
The problem is the full screen function.
All my clips are at 320 x 240 resolution, play fine and all in full screen on my pc , but
keep changing on my external dvd player.
Can anyone tell me why I do not always get full screen on some of these clips ?
Its weird because if I start viewing the clips at different intervals then either they are
a little to high and a black gap down the bottom, and or
a little to low with a black gap up the top.
This is really anoying as all I want is to view them at full screen. Some clips do
show up as full screen.
So why would some show up non-full screen and others at full screen ?
Is there any fix for this ?
How are you encoding them ?
It sounds like they may not have consistent aspect ratios set in the clips. You can check this (and change it if necessary) with mpeg4modifier is they are Divx/Xvid avi files. Make them all 1:1 PAR if they are not.Read my blog here.
thank u for your reply.
First I thought it was only the ones I encoded with media wizard
editor, because the ones I did with virtual dub had no problems.
I will now check all the 1:1 par settings on my devices & settings.
Studio14 HD Ultimate, can't open project files from ext. HDD!!!
By rivrbyte in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 15:49 -
LG DVX 482 H Player and ext. HDD DVD playback
By no-fast in forum DVD RippingReplies: 0Last Post: 11th Mar 2010, 04:33 -
Avi files not running properly
By Skyline in forum Newbie / General discussionsReplies: 6Last Post: 25th Dec 2008, 10:22 -
Problems with brightness shifting
By Jerry1964 in forum EditingReplies: 5Last Post: 18th Oct 2008, 08:51 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
