I seems that just about every time I play an AVI or a DVD through Media Player Classic, it always show subtitles and no matter what I do, I can't turn them off. To make things worse, it shows like two different subtitles on top of each other (like as if it is showing the DVD subtitles and the MPC is pulling subtitles from somewhere else). I really want to get rid of any and all subtitles. Can anyone help?
Thanks!
If you have a subtitle program like VobSub installed and your player also has a subtitle option, you can end up with two sets of subtitles. Turn one or both off.
This would happen with a video with a separate subtitle file, usually in the same folder as the video. Some videos off the net have hard subs that are encoded with the video and those can't be turned off. They would also not have a separate subtitle file most times. I don't use MPC that much, but it should have a option to turn off the subtitle display, most all players do. Look in 'Preferences or Options', whichever it has. -
Try: In "Options"->"Playback", uncheck "Auto-load subtitles"
Don't know if that will work for you or not - it was just a related option I found while poking through the options screen.
Jim -
hey.
go to view/options/misc.,2nd. box down uncheck.
go to external filters,look on right side for'vob',highlight,on right side check BLOCK.click apply exit and restart.
dennis -
Playing PGS subtitles with MPC.
By doctorm in forum SubtitleReplies: 2Last Post: 28th Jan 2012, 13:25 -
subtitles disappear using mpc-hc
By yaniryu in forum SubtitleReplies: 0Last Post: 27th Jan 2012, 12:47 -
.mkv subtitles in MPC
By andreyi in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 16:05 -
How to turn off subtitles in MPC using CCCP
By cant turn off subtit in forum SubtitleReplies: 1Last Post: 16th Jan 2008, 21:30
