y is this program WAY slower than any of the other one's i have? and is there any way to speed it up?
What codec are you using? (What format are you encoding to?) The speed of encoding is dependent on your CPU speed, your codec settings and the codec used. Generally, higher quality means longer encodes.
SUPER is a good all around converter, especially for odd format conversions, but if you are using any of the popular codecs like Xvid, Divx or MPEG, there are better programs out there.
And you can speed it up by reducing quality.
I use VirtualDub Mod most of the time with the Xvid or Divx codecs for those type of conversions. For DVD to Xvid or Divx conversions, AutoGK or FairUse Wizard.
For MPEG, usually the payware TMPGEnc encoder, or there are quite a few more encoders for that format. CCE is faster than TMPGEnc, then there is Mainconcept, Procoder, and other payware encoders. And a few freeware ones like HC or QuEnc.
Take a look in our 'Tools' section. Most of the widely used converters, codecs and encoding programs are listed there. -
converting any from or to h264 & x264 will be really slow, especailly converting MKV files with hi-res content and h264 codec
Hi,
Try WinFF: www.biggmatt.com Excellent all around Encoder with far less bloat than SUPER
Super 8 help
By overgroun in forum Video ConversionReplies: 4Last Post: 28th Dec 2011, 23:47 -
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29 -
SUPER
By Flying Doctor in forum Video ConversionReplies: 17Last Post: 6th Jan 2008, 06:52 -
Super Help
By fruitpassion in forum Newbie / General discussionsReplies: 2Last Post: 17th Jun 2007, 01:33
