I got avi that has little too much brightness on it. What's the best and easiest way to change avi color settings? Is it VirtualDub?
Hardware...Color Corrector
Levels, HSV, or Brightness/Contrast filters in VirtualDub are pretty easy to use.
I got brightness plugin in VD. When i'm changed the settings, what i do then?
Give VirtualDub a try. You can reduce brightness, but if there is no detail in the overly bright parts, you can end up with 'muddy' looking highlights.
I would try the 'levels' filter in VD first and check it with the preview in different parts of the video. You may have to fine tune the color or saturation with the 'HSV' filter or maybe the 'brightness/contrast filter'.
Lots of other VD filters available at http://www.thedeemon.com/VDFilter/list.html or http://neuron2.net/
EDIT: If you use any filters, you will need to re-encode the video by selecting a compression codec and settings.
how to change saturation and brightness levels to match original video?
By thrakk in forum RestorationReplies: 9Last Post: 10th Sep 2011, 07:58 -
How do I change from MKA to AVI?
By rocky12 in forum Newbie / General discussionsReplies: 48Last Post: 19th Jul 2008, 19:48 -
Need to change AVI to WMV!
By kane12 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 12th Dec 2007, 05:59 -
By jason_in in forum Video ConversionReplies: 3Last Post: 28th Nov 2007, 10:56 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 22:26
