new to this, have a sony vrdmc3 - using dv in - tried dvd+rw, dvd-r the sony starts to record for about 10 miuntes then stops and the little screen says "failed to record." Sony has been totally not helpful. No support - no return of email -
The first thing to try, is usually different media. Try a brand name disc such as Verbatim. From what I've read the Sony's are very picky about media, some even have issues with Sony brand media.
Aside from that, if it isn't working, return/exchange it if it's new and/or the repair shop if it's under warranty. It's possible it is just faulty.Google is your Friend
BD Rebuilder: ERROR "failed video encode, aborted"
By jlm86 in forum Blu-ray RippingReplies: 1Last Post: 22nd Feb 2011, 19:57 -
What is the problem when it says "failed video encode, aborted "?
By PERSHON in forum Newbie / General discussionsReplies: 8Last Post: 17th Feb 2011, 13:33 -
Panasonic DMR-ES35V "Self-Check Failed," refuses to run
By MattOKC in forum DVD & Blu-ray RecordersReplies: 2Last Post: 5th Jul 2010, 18:50 -
ATI AIW 9600XT, "TV failed to initialize the video" problem...
By etecnifibre in forum Capturing and VCRReplies: 11Last Post: 20th May 2008, 16:08 -
failed to connect Output pin 0x0093ae4c ["Stream 00"] on AVI Spli
By carcrashhearts in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2007, 13:46
