Used CutAssist 0992, 0994, it worked well.
The new 0.9.9.8 starts, but the right part of the programm ist cut. The older versions
have no problems...
What's wrong ?
I use a SAMSUNG 16:10 LCD, GForce 8800 GSX with NVidia 162.18 driver
Has someone an idea ??
Just use the old versions if they work better....
What are you cutting? avi, wmv? -
Used it for files from "onlinetvrecorder.com" - most *.mpg.avi
Since this problem I prefer TMPEG DVD Author 3 -
Do you mean that there are parts of the application missing on the screen (buttons etc.)? This has to do with your system font size (I suppose you have it set at 125%). This issue is currently being worked on. Try one of the development-Versions of Cut Assistant:
http://sourceforge.net/project/showfiles.php?group_id=192173
The latest is 0.9.11.17 at the moment.
Problems with display of File / Preferences
By Lehmeier in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2011, 05:06 -
Sub display problems with LG BD660
By jeffncris1 in forum SubtitleReplies: 0Last Post: 30th May 2011, 12:52 -
Problems connecting a laptop through the SVideo port to a Display VGA input
By jeproca in forum Newbie / General discussionsReplies: 21Last Post: 4th Nov 2010, 09:31 -
Playing Video on display 2 and display 1 goes black
By sidewaysdriver in forum Software PlayingReplies: 2Last Post: 3rd Aug 2010, 00:36 -
Wax display problems
By SearchQuality in forum EditingReplies: 0Last Post: 7th May 2009, 05:49
