I'm a total Noob at Video Capturing...
I just got a Hauppauge WinTV PVR USB2, I started recording an Aussie Rules football game (3.5 hours) that I have on VHS. I'm recording on Long Play, but after 20 minutes, everything locks up -- the longest it's gone for is 35 minutes
When I re-boot, I do have a video files that are from 500 MB to 1GB, I could edit them together, but that doesn't help if I want to record live TV?
Any ideas, is this a common problem?
Thanks!
Ed White made the United States' first spacewalk on 3 June 1965 during the Gemini 4 mission.
Lock-ups like this are often due to over-heating. The system locks up to protect itself. Encoding often pushes a system pretty hard because encoders (good ones, at least) are built to utilise as much CPU as possible. You should be able to record the whole game in one hit.
Questions :
Does this device encode to mpeg-2 natively, or does it use the CPU to do this ?
What are you encoding as ?
What software are you using to encode ?
Does the system lock up doing other encoding jobs or anything else that pushes it hard - say, 3d video games ?Read my blog here.
Mine did / still does occaisionally. I believe it to be a USB problem. It happens most often if I have a memory card plugged in. I have a VIA K8 chipset and have found changing (chipset and CPU) drivers helped.
I have been using the Hauppauge WinTV PVR USB2 for sometime.
The longest capture session I have ever done is six continous hours.
The Hauppauge WinTV PVR USB2 is a hardware encoder direct to MPEG2.
There are many things that can cause a system to lockup. I would contact Hauppauge Tech Support and ask them. I have found them to be very helpful.
You could also make sure that your Hauppauge SW and drivers are up to date.
You may fine some info on the http://www.shspvr.com/ site which is devoted to the Hauppauge products.
You could try:
1. run a temperture monitoring program to check the CPU temp
2. run MEMTEST to check the computer memory
3. defrag the harddrive.
4. make sure ALL fans are working and not blocked.
5. ensure that you are plugged into a USB 2,0 port
6. run a anti-virus and spyware remover
7. make sure that you have the correct USB drivers for you system.
8. Try the unit on another computer. If the problem follows the PVR then you may have a defective unit.
Hope this helps. -
Have you turned off your screen saver or change your power settings. Your power settings should be set at "never". Anti-virus should be turned off during recording, some do mess up.
Some simple ideas. -
I will give them a try this weekend
Thanks all for your input...Ed White made the United States' first spacewalk on 3 June 1965 during the Gemini 4 mission.
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 09:43 -
better unit than my old wintv pvr usb2
By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 10:52 -
Hauppauge WinTv USB2 Power supply
By canadateck in forum Capturing and VCRReplies: 4Last Post: 14th Nov 2008, 14:46 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19 -
Dilema: Hauppauge 99016 or WINTV-PVR-USB2?
By WetLight in forum Capturing and VCRReplies: 0Last Post: 11th Jun 2007, 05:42
