Hi,
I have a Dell laptop (D620, dual core, 800MHz with 1Gig of Ram) pretty powerful in terms of processing power. I have another old HP Desktop..must be 333 Mhz with 256MB Ram.
I use audacity software to do voice recording on my Desktop. Results were reasonable.
However, when I tried recording using my new Laptop, I am noticing a lot of delay in voice...If I record my voice (through Mic) playing a karaoke track using audacity, I can easily see that the recorded vocals lags the music track as if the sound processing is not real time.
I noticed similar thing with my old desktop but the delay was less noticable.
Does any one knows what the reason is and what the solution could be.
Have you tried record with something else to see if you get same problem? Could be some sound card issue.
Yes..I used the Sound Recorder tool in the Accessories-Entertainment..and it appeared fine. I have Windows XP running on the laptop and windows 2000 on desktop
Only powerful if both cores are running. If you are running XP there are two updates which may be necessary to enable both cores. Even so audacity probably will only use one core.
Once again it looks like Dell gives you less bang for the buck. Just about any HP, Toshiba, Lenovo or Acer in the stores has a faster processor. -
Audacity has an extensive online manual & user forum; also just released a new beta 1.3.3
http://sourceforge.net/forum/forum.php?forum_id=697567
the above link will take you to their forum link
AUDACITY - Records ONLY from MIC , on HP Laptop Win 7
By mrlewp in forum AudioReplies: 0Last Post: 12th Jan 2011, 22:54 -
Help-Brand new Laptop terrible quality DVD playback
By Stevethesearcher in forum Newbie / General discussionsReplies: 15Last Post: 29th Mar 2010, 14:53 -
Capturing in Premiere on a brand new laptop.
By havash in forum EditingReplies: 30Last Post: 31st Jan 2010, 15:37 -
Audacity--Interrupts During Recording
By solarblast in forum AudioReplies: 6Last Post: 25th Dec 2008, 01:05 -
Best brand of laptop?
By Tbag in forum ComputerReplies: 16Last Post: 7th Feb 2008, 23:59
