  1. I have a DVD in the VIDEO_TS folder that can be viewed ok, but when I create an ISO out of this folder, then mounting the ISO, the regional code pops up when I tried to play that. I thought that was somewhat odd, but is there a way to remove the regional code under the ISO format?
    Apr 2004
    Miskatonic U
    All ripping programs remove it by default. You can load the video_ts folder or the ISO in Shrink and make sure it is removed when you click on Backup.
    Read my blog here.
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    There'a free utility 'Free DVD' for removing it in DVD folder form:
    http://www.dvdfab.com/free.htm
    Aug 2007
    Australia
    DVDShrink removes the regions and also lets you set your own region limitations.
  5. Every method described here is good, but the fastest and the best method I found is to use PgcEdit because you can enable/disable every PUO and region coding in detail or enable/disable all.
    In PgcEdit select DVD/Region Code and press the "Region free" button. You can disable RCE in the same step.
    For PUO, select DVD/Filter Prohibited User Operations.
    And don't forget to save the DVD...
  6. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Free DVD (44kB) does it for RC, RCE, Macrovision + PUO in one button click, just point to folder.
  7. Free DVD (44kB) does it for RC, RCE, Macrovision + PUO in one button click, just point to folder.
    True, but if you want to remove just some of the RC or PUO you can't do it with FreeDVD. With PgcEdit is piece of cake, not to mention that you can enable/disable PUO for each VTS, apart from the global PUO removing.
    Jan 2007
    yes, but you need all that, unless you have some kind of instructional DVD you want to make sure parts can't be skipped.
    for a movie, you want to be able to just watch what you want to watch, just disable remove ALL protection and PUO's
