i have a home made DVD (not mine, someone made it), and each of the chapter is like 2 sec too late, is there a way to correct this? it's music so every time it's cut off 2 sec and it get really annoying
	Have you tried ripping the DVD and re-doing the chapter stops? It's worked for me in the past.
 Cheers!
 TTWC"I've got a present for ya!" - TTWC
	sorry for the noobish question, but do you rip it as each vob files? then redo the chapters?Originally Posted by TaoTeWingChun
	Hi-
 Demux the video in question using PGCDemux. The Celltimes.txt has the current chapters. To make them play 2 seconds earlier, for NTSC subtract 60 from each one, and for PAL subtract 50. Remux using Muxman. Add in the modified Celltimes.txt in File->Import Chapters. Also add in the M2V (video), the AC3 (if that's what the audio is). I don't guess it has any subs. If there aren't any menus, then after processing you're done.
 If there are menus and other videos you want to keep, open the original DVD in VobBlanker. Highlight the VTS containing the video in question in the upper screen, so it appears in the lower screen. Highlight it in the lower screen, hit the "Replace" button to the right and scroll to your new video with the fixed chapters. Give it an output folder and "Process".
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
