Im cutting the first 50 seconds off my movie...
okay so i save it as a mpeg and then i see it saving the movie but then it adds on like an extra 9 minutes or so and when i look at the preview its just black
wtf !?
Numerous possibilities, essentially the cutting prog is not finding your file completely agreeable.
If this file is ABSOLUTELY STANDARD, check codecs on your machine.
If this file is AT ALL UNUSUAL, such as a captured MPG, or one created locally, then I would suggest trying a different cutter.
I have had VERY GOOD success with MPG2CUT, it has yet to fail for me and handles files which choke other cutters, such as Womble, M2EditPro, Cuttermaran, and TMPGENC Merge and CUt. Plus it is free, and easy to use, as well. -
okay
MPG2CUT doesn't like my file.. gives me an error and i cant seem to close the window.. so i have to ctrl alt del.
http://img247.imageshack.us/img247/1068/60134675mu3.jpg
I ran my file in gspot
http://img247.imageshack.us/img247/8420/86129426oz3.jpg -
In the second image, from GSpot, it says "Codec(s) are not installed" in the top right, and it identifies the MPEG1 codec.
Simply download and install an MPEG1 codec and you should be good to go. It should be free and comes as standard with Windows, but I can't see one listed in the Tools -> Codecs section.
ffdshow is an option that might work.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Perhaps it's been corrupted? Try re-installing it.Originally Posted by chocolate_brownieThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Increase framerate without making the video shorter (or longer)
By FallenAngelII in forum Video ConversionReplies: 7Last Post: 7th Jul 2010, 17:02 -
MPEG-4 (DivX & XviD) movie discs no longer recognised by players.
By Sproggins in forum Newbie / General discussionsReplies: 11Last Post: 6th Sep 2009, 16:09 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
How to use Mpeg Video Wizard
By windranger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 09:24
