I have been off the pc and movies things for years now and trying to get back in to it a bit.. I have a simple question that I would like to ask.. I used to rip with smart ripper and dvd2one and tmpgenc... now days everything I find out there is in .avi format and I would like to know if there is a good simple program to encode .avi's to mpeg either 1 or 2 so that I can burn them to a vcd that will play in my stand alone player/ or is there a codec that will allow tmpgenc to read avi's?.. I tried burning avi's and they won't play.
Any help would be greatly appreciated..
thanks and forgive my stupid question, but the only question that is really stupid is the one not asked.
Modartist
	Modartist
 Some are born to rule the world. to live their fantasies.
 While most of us just dream,
 of what we would like to be.
	Thank you for the reply.. I am doing something wrong then.. as my tmpgenc will not load .avi files... it says unsupported file type.. Is there something new that I might need? .. I have my ac3 for my sound, and I used G spot to check everything .. it shows that I have all codecs needed .. I am at a loss here .. is there a .dat file or anything for tmpgenc that I might be missing?
  Modartist Modartist
	Sure, try ConvertXToDVD. It handles most AVI type formats off the web. Very simple and does a decent job of converting to DVD format. I would also recommend using ImgBurn for burning. VCD is a bit out of date presently, but you could try VCDImagerGUI or VCDEasy. I would only use VCD or SVCD if you don't have a DVD burner.
 You can also use Gspot 2.70 to identify the AVI or MPEG filetype and show other information.
 With TMPGEnc, you need to have the codec for your AVI type installed. And you may have to raise the VFAPI priority for TMPGEnc to recognize the file. See here: http://www.digitalfaq.com/dvdguides/convert/tmpgenc/tmpgenc.htm Look down the page a little for 'Problem opening source files'.
 And modartist, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:Thanks,Try to choose a subject that describes your topic.
 Please do not use topic subjects like Help me!!! or Problems.
 Moderator redwudz
	Thank you very much.. I appreciate your help.. I figured there was something I needed to do encode a .avi in tmpgenc... I will give your suggestions a try.. thanks again Modartist
	I found that a codec was corrupt or damaged somehow and reloaded them.. once I got that fixed I am able to do .avi's again in TMPGenc ..
 Hope that helps as it is the best suggestion I can give you .Modartist
	You need the proper codec. Analyze the file in GSPOT, see what codec is needed. Want my help? Ask here! (not via PM!)
  Simple issue, cannot find program to do it..need to split AVI with a FFBy serpa4 in forum EditingReplies: 17Last Post: 5th Nov 2009, 00:19
  simple avi editing programBy twotle in forum EditingReplies: 5Last Post: 7th Feb 2009, 22:19
  Good Program / codec to encode Flash Vp6 files to avi? Audio is Out of SyncBy hypnoticpimp in forum Video Streaming DownloadingReplies: 1Last Post: 14th Jul 2008, 01:25
  Simple MPEG-2 to DV-AVI converterBy TPFKAS in forum Video ConversionReplies: 4Last Post: 18th Oct 2007, 07:27
  Simple yet good... that can join my 2 parts avi video into 1By mai_hnf in forum EditingReplies: 6Last Post: 8th Sep 2007, 03:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
