Missing piece of info, is the 29.97 input a telecine source?
If not don't go there. -
Then for best results you IVTC it using an AviSynth IVTC filter frameserved into your encoder of choice. TMPGEnc has an auto IVTC which can be tripped up, and you can do a manual IVTC if you have a lot of time on your hands. Here's a guide:
http://www.doom9.org/mpg/tmpg-ivtc.htm
But anyone with any sense uses AviSynth's, Decomb, TIVTC, Smart Decimate, etc. -
The problem is that the source videos don't seem to have visible interlacing at uniform intervals. Eg, sometimes 3 normal frames and 2 interlaced frames and sometimes 2 normal and 1 interlaced.
Will the avisynth solution catch this and automatically adjust for it like TmpgEnc doesn't, because I have alot of clips and can't possibly do them manually. -
Hi-
And AviSynth has the only IVTC filters that can do this kind of thing without putting in the literally hours and hours per video that a manual IVTC in TMPGEnc might require.
Question about HD to SD and interlace>progressive>interlace
By ayim in forum Video ConversionReplies: 4Last Post: 10th Dec 2009, 12:21 -
interlace - progressive problem
By jin007 in forum Newbie / General discussionsReplies: 1Last Post: 18th Aug 2008, 10:55 -
Help! convert interlace to progressive
By craig198 in forum Newbie / General discussionsReplies: 13Last Post: 10th Feb 2008, 12:31 -
Interlace or Progressive??
By Browncoat in forum Newbie / General discussionsReplies: 9Last Post: 31st Jan 2008, 15:14 -
Interlace/progressive detector
By demonwarrior in forum Newbie / General discussionsReplies: 9Last Post: 6th Dec 2007, 00:35
