First file I've been unable to convert in Vegas 6.0c
Trying to convert to mpeg2
Vegas hangs until it times out when trying to import.
Can one of you kind folks offer a clue?
Here is the G-Spot info on the file -
http://img178.imagevenue.com/img.php?image=98400_GSpot_Screen_122_474lo.jpg
Thanks.
It would be easier if you uploaded the image to this forum instead.
Two things jump out immediately.
1. The audio is VBR MP3. Vegas hates VBR MP3. Re-encode it as CBR or uncompressed PCM and Vegas will have no problems.
2. Don't know how well Vegas 6 handles H.264/AVC.
Fix the audio first, then try again and see what happens.Read my blog here.
i think you're one version/update short of avc import.
just encoding?
or editing beforehand?
use one of the free mpeg2 encoders. loading with avisynth.
make it easy and use a frontend.
like FAVC.
if you need to edit,
use vdub and encode to a edit friendly format like dv, or go lossless with huffyuv
gl
Sony Vegas - Time freeze doesn't work
By Reiden in forum EditingReplies: 0Last Post: 5th Feb 2012, 14:11 -
Anything Adobe Premiere 5.1 does that Vegas Pro 8 doesn't?
By brassplyer in forum Newbie / General discussionsReplies: 5Last Post: 10th Jan 2012, 02:04 -
Problem: Sony Vegas doesn't open !
By freestyler09 in forum Software PlayingReplies: 6Last Post: 22nd Feb 2011, 15:59 -
Mpga Audio in Vegas 9.0 doesn't work
By NarutoS212 in forum EditingReplies: 3Last Post: 24th Dec 2009, 20:47 -
Sony Vegas 7 doesn't let *.mov & *.avi files be imported into project..
By koldun in forum EditingReplies: 5Last Post: 1st Jul 2008, 16:04
