If you demux subtitle with Dvd Decrypter it generates a file with extension *.sub.
It is not a text file.
What format is this file?
Is there a viewer for this file to view subtitles inside?
Can any DVD authoring program use this file?
It is a ".sub" file. It is subtitles in bitmaps.
Some authoring progs can use this, some can't.
Most subtitle viewers can view this format. Some can't.
To determine which are which, read the descriptions for the various progs in the Tools section.
While you are on that reading kick, keep going. Lots more goodies there and in the Guides section.
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
Demuxed Audio is longer than Demuxed Video, help!
By caesarhawy in forum EditingReplies: 3Last Post: 26th Apr 2010, 05:18 -
DVD Decrypter, AutoGK and Subtitle Times
By sambat in forum Video ConversionReplies: 5Last Post: 13th Feb 2010, 07:55 -
how to make a DVD subtitle as a default playing subtitle
By yozloy in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2008, 11:51 -
Demuxed Delay Help
By Nitro89 in forum AudioReplies: 22Last Post: 16th Apr 2008, 15:06
