ok here's my problem. I burn mostly axxo dvd movies. I've noticed that sometimes they come out cut off on both the left and right sides of the screen. My tv is a 4:3 ratio, not widescreen. I figured the reason for this problem was because nero was burning them in "automatic" aspect ratio, not 4:3.
So I changed the setting and made it burn in 4:3, and in the preview window as it was burning it was in letterbox so i thought I had fixed the problem. Then when I watched the dvd it once again is not letterbox, and is cutting off the sides of the picture! Is this problem with my tv settings? Or am i missing something?
Help would be appreciated, thanks for your time.
HavoK
You are in breach of the forum rules and are being issued with a formal warning.
axxo releases are without exception (afaik) illegal rips of commercial releases. That's something VideoHelp wont help you with.
Read the rules again, please.
There, you'll also find that you're supposed to start a new thread for a new issue. I've split this off from the thread you've hi-jacked.
/ Moderator mats.hogberg
Closed Thread
You are certainly missing the part in the forum rules about discussing warez and pirated material. Unless of course axxo is a new independent movie studio.
Read my blog here.
sides cut off on widescreen format
By rayzor02 in forum DVD RippingReplies: 14Last Post: 5th Aug 2011, 14:51 -
Adobe Premiere Elements 7 - widescreen dvd cut off on the sides
By bigmic789 in forum Video ConversionReplies: 9Last Post: 5th Aug 2011, 08:44 -
Cut sides of Vob Files
By sash! in forum EditingReplies: 3Last Post: 12th Nov 2010, 14:57 -
Edit something out of the picture ... Final cut/photoshop extended?
By perik in forum EditingReplies: 0Last Post: 29th Dec 2008, 10:27 -
Video cut on sides of TV of Burned DVD
By theguy1991 in forum Authoring (DVD)Replies: 6Last Post: 29th Jun 2007, 19:24
