my wife won a sony HT-DDW990 home theatre system from work. i hooked it up and have a coaxial audio cable running from the pioneer dvd player to the receiver.
the audio sounds good to me, but i'm wondering why the lit digital display shows "DOLBY DIGITAL 3 / 2.1" when a DVD starts playing... shouldn't it say "5.1" or is 3 + 2.1 = 5.1? The manual mentions nothing about what appears on the display. I think (can't find a dts right now) DTS discs say the same thing 'DTS 3 / 2.1'
this is my manual fyi...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HTDDW990
3 front 2 rear and the sub.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
You can try hooking up your PC's Coaxial Output to the reciever and see what the display says.
Whatever it says, you can then open up your Audio Card software and preform a Speaker Test to see if it will actually output sounds to each individual speaker properly. -
thanx. yeah, i'm pretty sure that i have DD and dts working... i think it's a Sony nomeclature thing... 3 + 2 +.1 = 5.1 The Sony self-calibration worked fine with the setup I have.
Yep that is Sony's system. I have an older Sony 5.1 dd and dts receiver. It says the same thing on the dd setting. Don't worry you're getting the 5.1.
"display aspect ratio" changes by itself after remuxing .mkv vide
By roise_r in forum Video ConversionReplies: 5Last Post: 2nd Sep 2009, 02:35 -
Dolby Prologic IIx. I understood that it will "create" a surround
By andrema71 in forum AudioReplies: 3Last Post: 6th Jun 2008, 11:22 -
Seeking "One-Type-Fits-All" format to display on iPod, PSP and Bl
By GrayStrickland in forum Portable VideoReplies: 0Last Post: 25th Mar 2008, 10:12 -
Can a Sony "full HD" TV (e.g. KDL-40D3500) display 1920x1080 via
By acnurb in forum DVB / IPTVReplies: 5Last Post: 26th Jan 2008, 01:59 -
"Sony Digital Imaging Audio" drivers problem...HELP!!!
By nick_gr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 2nd Nov 2007, 16:43
