After reading many post and burning probalby 75 1 min SVCD's (over the past couple of months), I still don't get the quality I want.My question is simple. Do I need to deinterlace during the encode? I capture from VHS at 352 x 480 (using huffy), and encode using TMPGEnc. I am making an XSVCD at the same resolution 352 x 480. The settings are using the standard svcd template except for the size (352 x 480). I say that I am unhappy with the quality because after about 45 seconds into the movie, it becomes jerky. Not the entire sceen, just people in motion. Other than the jerkiness, I am satisfied with the quality. If I deinterlace, I lose half the fields and it looks like a standard VCD.
Can anyone shed any light on this?
Results 1 to 1 of 1
Simple VHS Capture Questions
By mostly_useless in forum Capturing and VCRReplies: 4Last Post: 29th Dec 2011, 16:00 -
Simple Question re Premiere CS5
By jkholmes in forum Newbie / General discussionsReplies: 10Last Post: 3rd Mar 2011, 21:50 -
Is there a relatively simple program to sharpen up a VHS capture?
By Prynter in forum RestorationReplies: 4Last Post: 18th Jun 2010, 13:35 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
