Works fine half way. Then Quits. When I load the _s2d file to try and continue this is what I get.
The _s2d is complete movie, just not converted to the SVCD2DVD_OUTPUT folder.
Version: SVCD2DVD 2.5
Build: 2.5.3000.0
Type: System.UnauthorizedAccessException
Source: mscorlib
Message: Access to the path 'C:\Users\Erna\Desktop\New Movies\SVCD2DVD_OUTPUT\VIDEO_TS\VTS_01_1.VOB' is denied.
InnerException:
StackTrace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.SetAttributes(String path, FileAttributes fileAttributes)
at x3284ccece41ee22b.xe679539bc4bbd8b5.xfeff58ae51b05 fd0(String xd168ac2ed64c4662)
at x3284ccece41ee22b.xe679539bc4bbd8b5.x865d1dce05e7a 87c(String xc7faa4629ea73ace, Boolean x1ebdb8fb1e9908a0)
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Can you post the log for both runs? Logs found under the Help menu,
Problem: Convert RM to AVI using TinraGUI
By hzgg2 in forum Video ConversionReplies: 1Last Post: 13th Apr 2008, 16:53 -
Problem File, cannot convert it.
By sigung in forum MacReplies: 9Last Post: 14th Feb 2008, 12:15 -
Mov-convert compression problem
By Blå_Mocka in forum Newbie / General discussionsReplies: 5Last Post: 1st Nov 2007, 08:12 -
Problem with Mpeg2 Premiere Convert
By drgregur in forum Video ConversionReplies: 0Last Post: 27th Jul 2007, 14:04 -
convert x dvd problem
By tofu in forum Video ConversionReplies: 4Last Post: 16th May 2007, 11:13
