Hello
Im running Winxp Pro with Parallels, i have a copy of windows vista ultimate. which im trying to use in Parallels, Vista will install fine though i cant seem to get the internet to work correctly.
So far ive setup Parallels host-guest nic on my system, and installed the tools on the vista image. im using the default ip that Parallels had setup. On vista i went into the options and changed the ip address to match what Parallels used from there guide. no luck, has anyone had any luck setting it up, or know of a guide or something.
Never heard of Parallels.
Geting anything pre-existing to work with Vista is a total crapshoot. Low-level, complicated software is a more advanced version of this, you get covered with crap and then hope someone else would shoot you.
Is there some good reason you have decided to complicate your life by attempting to use Vista? -
just something to mess around with. i decided after trying to get it work long enough im not gonna bother. it may have something to do with my firewall blocking it. ill hopefully get a chance to fix it, if not ill just use vmware
I am trying to run Windows 7 using Parallels software.
By CHETOB in forum MacReplies: 3Last Post: 3rd May 2012, 18:52 -
Parallels Plesk Panel uninstall issue
By leghorn in forum ComputerReplies: 4Last Post: 24th Oct 2010, 07:22 -
Enabling V-Sync for old 2D Shooters in WinXP & Vista...
By retroborg in forum ComputerReplies: 2Last Post: 19th Apr 2009, 10:35 -
Solid State HD for WinXP Pro / Vista boot installation….
By retroborg in forum ComputerReplies: 2Last Post: 12th Oct 2008, 14:09 -
Vista 64 to internet
By mysts in forum ComputerReplies: 3Last Post: 19th Aug 2007, 21:25
