Hello,
I've downloaded a new firmware for my DVD-P370 and followed the instructions how to update the firmware but it does not work! The DVD player does not recognize the update disc...
I've buned 10 cd's in every combination but it didn't help.
Has anyone a idea?
Here's the firmware (czech samsung site): http://www.samsung.com/cz/Support/ProductSupport/Download/Model_Select.aspx?type=DVD+P...e=FM&language=
Thanks!
There are usually very specific settings in your burning app that need to be changed. At least from what I remember when I performed the update on my Philips.
If you are using Nero, try the settings here: https://forum.videohelp.com/topic271355.html?sid=ce5b6987216e9fcb457333b9e374af8a#1320169Google is your Friend -
Not all players can be flashed. First I would ensure you have the correct files for YOUR SPECIFIC player. Second, the instructions are provided on the link you supplied.
There is likely one of two possible issues: you are burning the disc incorrectly or the player cannot be flashed.Google is your Friend -
i don't think I'm burning the disc incorrectly because i tried EVERYTHING, no more options left...
I know a few people who have this player too and they can't flash it too, is there a way to ensure the player is un-flashable? -
First, unless you are having a specific issue with the player and know for sure that the new firmware corrects the issue, you shouldn't be flashing the player.
Second, if the flash fails, the player could be unusable AND you void the warranty.
If after reading and understanding all of the above, then your next step is to contact tech support. If the player can be flashed and a new firmware is available, they will tell you where to get it and how to do it.Google is your Friend
I've killed my Samsung BD-P1620 with firmware update :(
By DimensionOe in forum DVD & Blu-ray PlayersReplies: 4Last Post: 12th Jan 2010, 19:13 -
Making A firmware Update Disc Using ImageBurn Software
By tyfos80 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2008, 10:29 -
Samsung SH-S183L firmware update problems
By Dr_Layne in forum DVD & Blu-ray WritersReplies: 1Last Post: 8th Feb 2008, 10:36 -
Samsung TX-S3082WH (HDTV) firmware update via USB???
By Crazyj32 in forum Newbie / General discussionsReplies: 1Last Post: 16th Sep 2007, 19:47 -
Samsung DVD-P370 region free needed
By Master78 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 19th May 2007, 22:27
