Results 1 to 12 of 12
    Jul 2007
    can this program encode avi's into different formats such as WMV or MP4[/i]
    No, it can't convert to wmv or mp4 containers.
    Jul 2007
    shit can it convert to any other format?
  4. OGM and MKV. MPEG with YMPEG installed.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    what are you going to do? there are other tools out there...
    Jul 2007
    i wanted to make my AVI into a WMV, and i was also wondering which one is smaller in size a AVI or a WMV
  7. Originally Posted by OG24
    WMM or WME.
    It depends on the codecs you use. AVI and WMV are containers. They can contain video compressed with any codec you want (although WMV usually contains video compressed with Microsoft codecs like WMV3).
    Jul 2007
    the codecs i can use are xvid and wmv3 so wich will make the file smaller, wich willl make it look better
  9. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Size = bitrate x running time. The lower the bitrate, the smaller the file. The question you need to answer for yourself is which codec looks best at the lower bitrate ?
    Read my blog here.
  10. Mod Neophyte redwudz's Avatar
    USA
    If you are not interested much in quality, just small size, go with WMV. But Xvid can be played on most set top Divx players if you use the proper configuration. WMV doesn't work with many software players outside of WMP and very few stand alone players. Either codec will do low bitrates and small filesizes. But WMV may have the edge on small VS quality. At least between those two choices.
    You could make up a short 5 minute representative test file and try it with different encoders and see if the format and quality are what you want.
  11. The difference between Xvid and WMV quality at low bitrates (small files sizes) is mostly a matter of personal taste. Xvid will be a little sharper but will have more macroblocks. WMV9 will be a little fuzzier but have fewer macroblocks. WMV9 in a WMV container will drop the frame rate if the video would otherwise be too badly degraded. This leads to jerky action scenes.
    Jul 2007
    ok thank u
