I pulled a 23.97 frame rate video off of a DVD and VIrtualDub-MPEG2 1.6.15 tells me it's 29.97. I was able to correct this by turning off some kind of flag that vdub uses before and it was all good. But now......for the life of me I cannot figure it out.
Could someone be so kind as to walk me through that and how to turn it off so that vdub sees and processes it as it was meant to be.....23.97
Thanks guys.
I really need to stop drinking and editing. lol
-vodmare.
www.matttstubbs.com or www.youtube.com/matttstubbs.
Yes there are 3 t's in MATTT.
	My problems is that when I use VIrtualDub-MPEG2 1.6.15 it doesnt change it. It remains 29 fps. But I went back to and earlier versions and that seems to treat it just fine as far as I can tell.
 Thank you for your help and any other ideas you might have.
 -vodmare.
	I have 1.6.15 too. The settings works for me. With the option enabled opening a VOB reports 29.97 fps and you can see comb artifacts. With the option disabled opening a VOB reports 23.976 fps and there are no comb artifacts.
  Forgot to tell DVDFlick to burn a disc...By alhenderson in forum Authoring (DVD)Replies: 3Last Post: 21st Sep 2009, 14:15
  -ss / -t flags?By richlyon in forum ffmpegX general discussionReplies: 3Last Post: 9th Mar 2008, 09:58
  Forgot how to backup 7.5 GB DVDBy Nilfennasion in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2007, 09:53
  Cant use Program. Forgot e-mail used and serial.By Mr_Del in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 18th Aug 2007, 20:49
  Forgot to add link!By Brainfire in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd May 2007, 20:11
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
