Hi
I've just started using Encore 2.0 to author my DVD's. the problem I have is that I'd like to make the main movie sit on the inside of the DVD (near the centre where there's less likely to be as much vibration.
I tried DVD Lab Pro, which let you specify this, but seeing as Encore is part of the Production Suite that we bought we figured it would be cheaper to use it instead.
Is there any way in Encore to specify where on the disk (physically) the movies should go. i.e the more important ones on the inside, the less important (extras) on the outer edge?
I looked for that option when using the TRIAL version, but could not find it. But I might have missed it, or it might have been excluded from the TRIAL (I cannot say with 100% certainty, but I don't think you can do it within Encore 2.0).
Regards,
George
Encore cuts off end of movie
By koberulz in forum Authoring (DVD)Replies: 0Last Post: 23rd Jul 2011, 00:17 -
DVD Lab Pro - New OS, same location of files = Subtitle generation = crash
By Paker in forum Authoring (DVD)Replies: 5Last Post: 18th Sep 2010, 09:56 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 02:52 -
DVD player location
By didikai in forum ComputerReplies: 1Last Post: 26th Apr 2008, 19:22 -
Premiere Pro to Encore DVD. Export movie or Encode?
By vid83 in forum Newbie / General discussionsReplies: 1Last Post: 18th Nov 2007, 05:37
