I was given this Sony S-Master 5 disk changer a few weeks ago because something was jammed in it. I never bothered connecting it to a TV while I worked as the whole problem was ejecting the disk trays... Well now it works so I decided to use it. However, every output on the device has static in it! It looks about like there's a short in the cable, but I have tested different cables with the same results. Component and both RCA outputs have static. However, the RCA audio output is fine, its just video. At times when the motors are working, the static seems to clear up, but only for a second.
I really didn't disassemble it too much... I don't know if I knocked a ground loose or something, but as far as I can tell, everthing's straight inside.
	Aside from the obvious of looking for something damaged inside, there isn't much you can do. A repair shop would be your best bet, but only if it is under warranty (which it doesn't seem to be in your case). Google is your Friend
	Thanks... Eh, I'll probably just end up giving it away or something. I had high hopes in using it as a backup stereo in another room, but honestly it sounds pretty pathetic. Aside from my video problems, the sound is pretty muffled and I see no tone adjustments.
  fuzzy text/desktop display with Sony Bravia TVBy Bacillus98 in forum Media Center PC / MediaCentersReplies: 12Last Post: 24th Feb 2016, 13:29
  I know this get's asked alot, but best playback on my Sony BraviaBy kbphoto615 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 02:39
  8mm Videotape Playback issues on Sony VTRBy nazopo in forum MediaReplies: 1Last Post: 22nd Dec 2010, 20:47
  Staticy/distorted audio exp'd when copyin some home-rec'd VHS movies to dvdBy corneileous in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2008, 18:33
  "Master" Master Audio Volume Control?By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 09:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
