Hello everyone
I have a problem with DVDlab pro and motion menus.
What I did:
I created a motion menu by dragging a video and audio file onto the menu sheet.
Then I added some "buttons"(just text) and linked them to movies.
All movies and menues are in 16:9 format and I have also specified 16:9 in the project properties. The problem is with the colors:
because I like to have the button text to appear in white color(normal), yellow(selected) and red(activated) I configured the color map accordingly with the 3rd slider.
When I simulate the menu and even when I compile the DVD and play it with nero player everything is fine. If I play the DVD with a desktop DVD player on a 4:3 TV set then the movies have black bars on top and bottom(letterbox) which is OK. The problem is with the motion menus, on the 4:3 TV set the top and bottom bars appear in WHITE color. I found out that this color changes when I change the color map of the buttons in normal state.
What I mean is if I change the color of the button text to black(normal color map, slider 3) then the top and bottom letterbox bars also change to black.
This only appears with motion menus the color of the letterbox bars of the movies is always black.
Question:
What do I need to do to have black letterbox bars with the motion menus but white button text on the buttons???
Do I need to do "Motion Render" to overcome this???(I haven't done this yet).
If possible I want to avoid any reencoding of the motion menue clips to maintain the quality.
Many Thanks for any hint on this.
Regards
Sektionschef
It appears DLP uses GROUP-3 for the Letterbox Background.
So, change each of your buttons to use GROUP-2.
Make sure that GROUP-3 NORMAL is transparent (slider to the LEFT).
Regards,
George -
Many Thanks for your answer.Originally Posted by GeorgeW
This has fixed the problem!
Currently I have the group3 normal slider on the right side(solid) and it also works.
Why should it be on the left side(transpareent)?
Regards
Sektionschef -
You don't have to if it works the way you have itOriginally Posted by sektionschef
Regards,
George
DVDlab PRO : Motion menu, cells, missing button highlights !
By TheCap in forum Authoring (DVD)Replies: 18Last Post: 13th Jul 2011, 12:14 -
Motion Menus in DVDLab Pro question
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 1Last Post: 8th Mar 2009, 17:47 -
How can i do switched menus with videos in Dvdlab pro?
By wan2no in forum Newbie / General discussionsReplies: 1Last Post: 26th Jan 2009, 00:54 -
Free Software for Motion Menus?
By thomasj in forum Newbie / General discussionsReplies: 5Last Post: 21st Nov 2008, 15:03 -
Motion Menus in DLP
By ckurowsk in forum Authoring (DVD)Replies: 8Last Post: 8th Sep 2008, 09:23
